jl audio amp asking $100 plus shipping also pioneer amp $50
FOSGATE JOE
R.F team and 49er fan!!!!
1,509
CALI
Item(s) for Sale: jl audio amp
Item(s) Description/Condition: used, only used for less then a year.Yes works great
Price: $100
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
jl audio amp is 1000 watts rms modle number is mono subwoofer amplifier
400 watts RMS x 1 at 4 ohms (700 watts RMS x 1 at 2 ohms)
1,000 watts RMS at 1 ohm
Class D amplifier design
differential-balanced inputs
MOSFET switching power supply
frequency response: 10 Hz - 160 Hz
variable low-pass filter (40-300 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 45 Hz)
wired remote level control included
preamp inputs and outputs
speaker-level inputs
fuse rating: 35A x 3
4-gauge power and ground leads and a 100-amp fuse recommended — wiring and hardware not included with amplifier
14-5/8"W x 2-3/16"H x 9-5/8"D
pioneer amp PWM Regulated MOSFET Power Supply
Bridgeable 1/2/3 Channel Capability
Balanced Isolator Input Circuit
Oversized Screw-Type Power/Ground Terminals
Screw-Type Speaker Terminals
RCA Inputs
Hi-Volt Input Level Control (200mV-6.5V)
Selectable Crossover: 80Hz, -12dB/oct. (LPF)
Specifications
Continuous Power (14.4V): 125Wx2 (4 ohm), 190Wx2 (2 ohm), 380Wx1 (4 ohm)
Max Power (14.4V): 250Wx2 (4 ohm), 760Wx1 (4 ohm)
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4W)
Signal-to-Noise Ratio: 100dB (IHF-A)
Dimensions: 11" x 2-5/16" x 12-3/4"
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
FOSGATE JOE
FOSGATE JOE
CALI
dude661
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
