JL sub problems
Master69
i have some wuestions about these jl subs im picking them up off of a trade and i want to know which 2 will be easier to fix..obviously the 2nd will be easiest but what would be harder to fix 1 or 3?
1: Has 1 broken tinsel at cone. Measured both VC and it shows 3.5ohms. Overall in good condition. Just don't have time/skills to fix the tinsel lead.
2: Has 1 broken tinsel lead near the connector. Very easy fix and all VC measures 3.5ohms.
3: Works fine, has a 1 inch approx tear in the surrond. Can be patched up or surround can be replaced easily with a replacement kit.
444
465
572
701
Master69
Master69
Burlington, Iowa
Dirtrider4eva
    Jun 1, 2024
    May 31, 2024
