JL W6v3 10" in a sealed made for W3V3
  • 2
mrpep
chicago
I have a 2004 sequoia with 12" w6v3 ported to spec, sounds great but need to sacrifice car audio for space so I ordered the stealth JL W3V3 10" for my vehicle.
The stealth comes with a 10" w3v3 and the cut out hole is 9" just like the 10" w6v3 so a 10" w6v3 will fit in the stealth box. The w6v3 is 1" longer than the w3v3 but so is the recommended sealed box for the w3v3 vs the sealed for the w6 so my stealth is literally 1" longer and will accommodate my w6. Then there's internal area. The W6 is recommended .55 c/ft. for a 10" sealed and the w3 is recommended .620 c/ft. for sealed which is about 12% over the w6v3 recommended spec. Bottom line, this stealth appears to be able to accommodate my w6v3 very well. Does anyone else see what I see?
Are you referring to the enclosure size, if so, seems that box would work well with the w6 as long as depth works out.
I feel the same way. I do wonder if the build of the stealth can handle the additional 200 w rms of power of the w6v3 since it will apply more forces, stress to the glues and whatever is used to hold the enclosure together. . It should be strong enough, I hope.
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
And you (if you’re not a Ai BOT), for the sake of everyone in this forum, may want to quit posting, Your information is consistently off topic and...
48
6K
They have pre-cut wood if you pay extra at the hardware store. Just draw it out. But you'll have to pay extra. Then screw it in yourself...
mrpep
mrpep
chicago
mrpep
Brendon Jenness
    May 8, 2024
    May 8, 2024
