John's build for (2) 18" SSA new line subs, line not available yet!
soundsolutions
Pro Seller
SoundSolutionsAudio.com
1,468
Potsdam, NY
Ok building a small box here...here's the specs.
Volume: 14.4ft^3
Port : 187in^2
Tune: 31 hz
Ok, I'll give a pic, before anyone asks, we don't have pricing or specs on them yet, all I can say is they will be a 1500wRMS range driver. We don't even have a date range on when they will be available. They will be in 12" 15" & 18" versions though. Black baskets, and some cosmetic changes will be made.
***15" Version pictured.
Got most of the deadening done today. Burned through a huge box of it. Thanks to Second Skin Audio for such a fine product! //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
Ok, since the roof was the worst part of this blazer, we put 4 layers on that bad boy and let me tell you, it's solid now. I hope those 18's don't rip this apart. On to the pics.
update...
Well going into this build we knew that there where two huge main concerns with the "prep" work.
1. Make that roof solid
2. Get rid of all the rattles that have plagued that poor blazer (GM's poor design)
So, after 4 layers deep on the roof I feel confident that we solved that problem but the squeaks and rattles where a whole new issue now that we got to put the truck back together. Since we didn't get to the doors yet deadener wise (ran out) I thought i'd run down to the fabric store and pick up all new fasteners for the doors since those cause alot of the squeaks.
Added all new fasteners to the doors, carefully assemblied the rest of the truck back to it's original self and isolated only two rattles left which I feel confident we can fix tomorrow with some double sided sticky tape. Here's a few pics of the truck back together...then it's on to the box and the rest of the system...anyways, here's a few pics.
ok, updates are in. Got a brace between the woofers mounted in today, after the double baffle goes on should be plenty sturdy enough. Tomorrow, i'll put on the baffle and cut out the holes, paint the port etc...anyways, on to the pics.
finally....I cut the holes! //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif this thing looks sexy. IMO anyways.
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
948
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
soundsolutions
Pro Seller
soundsolutions
Potsdam, NY
IamDeMan
    May 31, 2024
    May 24, 2024
