JVC KD-SHX700 not playing MP3's
  • 2
scarnan
Okay, got my head unit about a month ago, made a few mp3 cds, none work so far....made then with the songs in folders, songs just thrown on the cd, renamed them all so there real short names, everything...none work it acts like its playing it just fine just no sound comes out....the timer is running and everything
BUT
my friend had a mp3 cd and it played fine i was using TDK(which works fine for non-mp3 cds that i burn), a cheap brand called Optimum which also works fine for non mp3 cds....the one that my friend used that worked was a K-Hypermedia which usually **** but for somereason worked...im burning with Nero
any help, helps lol
make sure you don't have wma's and mp3's in the same folder... some headunits won't allow this... read the manual about mp3's and it'll give you some troubleshooting techniques in there
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on...
970
scarnan
scarnan
Baltimore , MD
Slody4Futbol
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
