Problem Child 10+ year member
If i had a mono amp and 2 subs, would i be able to devide the output and push my subs?
ProblemChild - completely ignore his post. He's messing with you.No if you have a mono amp that means you can only hook one sub up to it.
no.yes you would need 2 two ohm dvc subs to be able to wire down to 1 ohm
Oh wow I dont know how I messed that one up lol //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif Yea 2 4ohm dvc subs to be able to wire down to 1 ohmno.
you need two dual 4 ohm subs to wire to 1 ohm.
if you have two dual 2 ohm subs, you can either wire to 0.5 ohms or 2 ohms.
Geez man calm down I just made a simple mistake. Its not like I was purposely giving him bad advice like other posts in the thread did...the ****** stupidity in this thread is killing me and that is not directed towards You OP.....
if u have a mono amp u can hook up any amount of subs to it as u want as long as u do not go below the minimum independence....
if u want to run 2 Dual Voice Coil Subs at 1 ohm then the subs Need to Be Dual 4's
