Kenwood KAC-9104D Amp Getting Really Hot Really Fast
  • 4
#CW!!ZERO
Ok so a little background on my system, I had just one Alpine Type R sub powered by this amp for the longest time, I had the sub wired to 4 ohms and it recieved 500 rms. Well for my birthday my mom got me another sub for my truck. They are both dual 2 ohm subs and I have it wired so that the output is 2 ohms now, so that is 450rms per woofer. I used this website Rockford Fosgate® - Woofer WiringWizard
It never used to get hot when I had just the one woofer and yesterday for the first time it cut out on me and I was startled. When I felt the amp it was scorching hot. It gets sufficient air and I have 6 guage welding cable for power and ground (about to switch over to 4 guage tonight). Does anyone know what is going on?
The 9104 and the 8104 are both rated for 2ohms, but neither will run 2 ohms continuously without going into thermal protect. Kenwood makes good HUs, but their amps are junk.
Dang I was hoping that wasnt the reason, what would you guys recommend for a amp that will put out 1000 rms at 2 ohms that I can split between my type r woofers. A best for your money answer would be nice also.
Thanks guys
*EDIT*
Just looked at a Alpine MRP-M1000, puts out 1000rms at 2 ohms. Is there anything better for lesss money?
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
975
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
402
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
699
#CW!!ZERO
#CW!!ZERO
Fayetteville, GA
stanky1219
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
