kenwood ps 150
  • 3
i have this old kenwood ps 150 that has been in the closet for a couple of years the other day i took it out to but un my brothers car to push 2 jl 12wo's but as soon as we turned the car on both the fuses blew. we tried it three times and every time we turned the key over they both blew. then i took my amp out of my car and hooked it up and it worked. i don't understand because it worked till the day i took it uot of my old car when i got my new amp. whats up with that!!!!!!!
You sure you didn't wire it wrong or have the amp grounded somewhere it shoudln't have been. The only thing I can think of that would cause that is reversing the power and ground wires.
Definately sounds like a wiring issue..
If you are blowing fuses- either the power or remote wire is shorting to the vehicle chasis some where. Take a look over your wiring for any possible places this may be happening.
Take it easy,
-zane
yea but if it was a wireing problem then why when i took my amp out of my car i hooked it up it worked i know that i did not cross positive and negative and i have a good ground any other possible causes????????
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
392
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
955
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
690
big daddy bass
big daddy bass
kansas city mo
big daddy bass
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
