kenwood ps 150
i have this old kenwood ps 150 that has been in the closet for a couple of years the other day i took it out to but un my brothers car to push 2 jl 12wo's but as soon as we turned the car on both the fuses blew. we tried it three times and every time we turned the key over they both blew. then i took my amp out of my car and hooked it up and it worked. i don't understand because it worked till the day i took it uot of my old car when i got my new amp. whats up with that!!!!!!!
You sure you didn't wire it wrong or have the amp grounded somewhere it shoudln't have been. The only thing I can think of that would cause that is reversing the power and ground wires.
Definately sounds like a wiring issue..
If you are blowing fuses- either the power or remote wire is shorting to the vehicle chasis some where. Take a look over your wiring for any possible places this may be happening.
Take it easy,
-zane
yea but if it was a wireing problem then why when i took my amp out of my car i hooked it up it worked i know that i did not cross positive and negative and i have a good ground any other possible causes????????
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
571
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
815
big daddy bass
big daddy bass
kansas city mo
big daddy bass
    Jun 1, 2024
    May 31, 2024
