Kicker S8L5 dual 2ohm
  • 1
Talontsi90
CarAudio.com Exclusive
400
32
488
975
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Talontsi90
Talontsi90
Talontsi90
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
