Kicker zX1000.1 actual power?
mine had 1305 watts on the birthsheet hah.. it depends on your alt though. my old T-bird had a 130amp stock and my fox body has a new 200amp alt so if your car has a decent one, the big 3 will be just fine. if its a super weak alty like those found on foreign compacts and older volvos, youll need an upgrade. you can get a ZX1000.1 off of here for about 200-240 bucks. i have one i can sell you for 240 if youd like. pm me if youre interested or something but if not, woofersetc.com and some ebay stores would be fine.
I drive a 97 Pontiac GTP, I think the stock alt is like 105amps. Do you guys think this will need to be replaced?
You might be able to get away with the Big 3 and an upgraded battery for the time being. I ran 750 watts RMS in my 1997 Civic off the stock alternator with a Kinetik HC1400 and had no problems. The stock alternator was 80 amps. Hell, I even ran 1,500 watts RMS for a while with the stock alternator, but I had to charge my battery every now and again.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
812
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
toledokid
toledokid
Toledo, Ohio
metsfan89
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
