Killing amps by voltage drops
shava
ShaversDaFlava
367
Salem, OR
I kinda see some people around here saying the amp was probably dead because of voltage drops.
How true is this and say your electrical drops to a minimum of 13.8v is that really going to kill an amp over time?
So when an amp dies randomly its most likely bad build quality?
I just don't understand why an amp will work fine for like 8 months then just stop one day and blow something.
Well a test tone ran me down to 13.9v after like 20 seconds or so when I had the amp.
And it was at 2ohms so thats fine for that amp.
Im just trying to keep my next amp or if this one gets refurbed from frying again. If you are clipping the sub with the amp does that hurt the amp at all?
There are a lot of things that can kill an amp. There are also a lot of things that can either come loose or stop working on an amp. Do you have any pics of the inside?
Did you blow an amp? What amp? What were the circumstances?
Dropping to 13.8 volts won't kill an amp. However, having an inaccurate instrument measuring the drop and telling you it's at 13.8 when it's at 11.9 will blow an amp.
But who knows what exactly happened. If you show us some guts there are guys on here who can identify what blew or burned and then guess at how it could have happened.
Thank you to everyone who has given me advice so far. I have not had the chance to make any changes yet (truck driver). I don’t get much down...
177
423
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
shava
ShaversDaFlava
shava
Salem, OR
Silverbane
    May 18, 2024
    May 18, 2024
