LF Advice on buying new speakers and what not
  • 4
Ok thanks, So I think you're saying I would use 1 single 12" sub? I was planning on getting two.. But Thanks for keeping the budget small. Id like room to upgrade.
two JBL GT 5 12s Dual voice coil
Polk db 6501 comps and its matching rear coaxial(you can find it for your size)
and one ppi Phantom 4 channel to run it all.
Ok sorry I'm a bit confused... So the Polk db 6501 comps is the two front speakers + tweeters and then the rear coaxial means that it's two other speakers for the rear doors. So in total 4 speakers two tweeters..?
best thing is, in the future, that 4 channel amp can be used for pure mids and highs when you decide to add a dedicated sub amp with beefier subs.
That 4 channel amp will be future proof basically because of how much power you are getting.
---------- Post added at 06:59 PM ---------- Previous post was at 06:59 PM ----------
yup
yup
So how big of a ***** will this all be to setup? My car is a Jeep 2000 grand cherokee with the infinity system which means that I have two tweeters above the dash and then an Amp under my back seat to power the speakers and tweeters. I'm hoping I don't have to run new wire....?
Its a full on Install job wires and everything.
oh those are the coaxial version? I figured it was something different since it said liquid cooled silk tweeters. I also hope liquid cooled doesn't mean i have to do something with it..?
Sweet thanks, So just out of curiosity would this setup be pretty interchangeable for like If i got a new car? Not like i plan on getting a new car soon just want to know in case i find something or my car finally dies. I can't imagine it would be too hard to take this stuff out and put it in a new car?
yeah you can easily take everything out and recycle. A lot easier than installing it actually.
Sweet!, I don't plan on exactly doing that but I really don't want it to be a living hell to move stuff to another car. Thanks a ton for your help I think I'm gonna go ahead and buy most of this stuff right now. Not sure if this is a good idea but since i can swing that much money right now I might buy just the subs, amp, and coaxial speakers since i already have working front's and then ill buy the front's later...? Can i run just subs and rears off the amp? or just subs for that matter?
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
369
It also lowers the amps efficiency and raises the current draw.
5
499
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
642
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
9
782
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
Jcdanible
Jcdanible
OAHU
Jcdanible
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
