Southwest Region Lights still dim?
AZ,CA,NM,NV,UT
BassikCivik
I have 2 rockford fosgate p3 12" with my prime 1200.1 and they are wired to 1ohm
I added an extra battery to my car and ran it to the back with 0g sky high wire and from my amp to the batt I'm running 4g wire.
Problem is that my lights still dim !
The battery is an hc1200-BLU and this is all in my 2015 Honda Civic.
I'm not sure why they dim but it only happens with certain songs and starts when my volume is about 30 (max is 40)
Help? Any info or ideas helps thanks
Trying to get lights to stop dimming
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
747
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
added a 32AH bank to my system...... Cot damn! Now we rockin. Voltage staying above 13 wide open!! Just thought I'd update.
BassikCivik
BassikCivik
Phoenix, AZ
mylows10
    May 18, 2024
    May 16, 2024
