Looking for a tweeter to play at 2kHz with high eff...please advise
  • 2
maxmil982
I'm building a 2way front stage and am looking for a tweeter that can play down to 2kHz and has an Fs @ or <1k, that also has high sensitivity ( >92db 1w/1m). Any suggestions will help a lot. Horn or large format tweeters welcome, but I'd like to stay at 2" max if possible.
Also the amp it's going to does 145rms @ 4ohm
And 225rms @ 2ohm
Thanks in advance
What you're asking is not feasible if you have any interest in playing the system hard. Tweeters of that size are readily available with an Fs well below 1 kHz, but a High Pass Filter of roughly 2.5 kHz with a steep slope is wise to lower distortion and prevent mechanical damage.
Is there a larger and/or compression tweet that you know of that will be more suited to play down to 2k at high volume?
I ask because my build is somewhat unconventional, it seems, and the mids I have will require a tweet that will be crossed at 2k...
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
Excellent choice on the SSA Evil's. :)
28
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
maxmil982
maxmil982
Atlanta, Ga
trumpet
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
