Maxima Performance
Slammed
Striking Accord
Well I got my 96 Maxima pushing around 230 hp
my mods:
Stone Racing Y-Pipe (15-18 hp)
Magnaflow Hi Flow Cat (2-3 hp)
Warpspeed Catback Exhaust (4-5 hp)
Weapon R CAI (5-7 hp)
Unorthodox Racing Crank Pulley (8-10 hp)
I was wondering what other boltons are available for me that will total under $1000 and give me around 25 more horses.
I was thinking Nitrous...but I heard that wears down the engine...
also...will these mods add significant HP gains??
-Fuel Pressure Regulator
-Engine Ground Wires
-Breather Filter
-MSD Ignition
-NGK Spark Plugs
thanks
i highly doubt you're seeing that power at the wheels. that's probably at the crank. also, the muffler probably freed up only 1 hp. i highly recommend checking out http://www.forums.maxima.org
i drive a maxima myself, and that site is priceless when it comes to anything maxima related. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
my mods:
-Breather Filter
-MSD Ignition
-NGK Spark Plugs
thanks
me and a buddy had his '96 running nice, we called her the torque monster..
he had 300zx fuel pump and injectors
ngk cold step plugs
intake, y pipe, full catback @ 3"
100 shot wet kit
exedy stage 1 clutch
and it ran until it got smashed, best time slip in the 8th was an 8.4 on slicks
he also did the 5 speed conversion with another friend....
but oh how things change, we are working on turnin his next max into a 12 second turbocharged max...
but as was stated before...http://www.maxima.org is gonna be your best bet on mods, full of resources....good luck and post some pics if you got them
my mods:
LOL, I suppose you're guessing, or did you actually take it to the dyno?
Get good suspension first.. then work on the engine :0
I also drive a Maxima. The mods you have listed are about all you can bolt on. I would guess you are much closer to 195-200hp at the wheel considering your mods. I would look into a Greddy E-manage. This will alow you to "tune" your current mods. Also see if Technosquare has an ECU for the 4th gen Maxima.
They have already surpassed the 12sec mark. Deep into the 11's. I will post a link if I come across the thread.
and...???? tell me something i dont already know, i read the maxima.org forums
I just clicked on six separate threads and they went well. Seems to have worked.👍
9
981
Here is a chart that gives you relative cone size. Diameter of speaker*|*Cone area of speaker in square inches 18"*--->*254 15"*--->*192...
15
3K
I have the same issue.... 4dr sedan. Trunk is a bass trap. Ski pass is the only opening to the cabin. Forward firing, pretty well sealed off...
7
Poly fill traps the rear wave of the speaker keeping it from reflecting back and hitting the cone. This reduces 2nd order and 3rd order distortion...
9
Slammed
Striking Accord
Slammed
Gotham City, NY
datguyclark
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
