MidRange/MidBass 6.5s that like 250-350 watts @ 4 ohms???
  • 4
So I'll tell you what I know.
They can take a ton of power though I've only been able to give mine 150 or so.
They don't go too low, think 75hz-90hz as a x-over point.
They kick ass in the midrange, they make snare drums sound good and tight.
The Manual says 275max, they might take 300 but I dunno if I'd do that for long periods of time.
The more i look at these different drivers you mentioned squeak, the more i find that they mostly have a nominal impedance of 8 ohms...
How do you wire a pair of those into 4? or 2 for that matter? Or anything that can run on the average 2 channel amp?
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
I know, generally speaking, that doing what you’re doing will give you some semblance of what the end result “should” be. That said, driver types...
Worth it? That depends on your thoughts. When I upgraded from 2 way to 3 way I was very happy, but when I did that I made pods and moved speaker...
twoohfour
okay
twoohfour
Where you live (Ex. Los Angeles, CA)
squeak9798
    May 16, 2024
    May 16, 2024
