Midrange Speakers
  • 4
Buy decent $100 drivers... hell that's easy.. spend the rest on damping the doors...
I mean to say that really most 100 watt drivers will do... but damping the doors is what will make the most difference...
I've seen a $50 component set that was in some doors done right outperform a set of $300 dollar Focals that were put into an untouched factory location...
so is it a good idea to hook midrange speakers on amplifiers where HPF has been set?
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
I know, generally speaking, that doing what you’re doing will give you some semblance of what the end result “should” be. That said, driver types...
7
rfkjustin
rfkjustin
delano, ca
ilikeradios
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
