Mmats sq-4160 4 channel amp
  • 4
rwlaney
29
tega cay
1 used but in good condition mmats sq-4160 amplifer
Item looks good and works good only 2 issues 1st the screws are missing to connect wires and 2nd is that the filter switch on the 3rd and 4th channels must of had some dust in it because I had to cycle it a couple of times for it to work. The switch works great now just wanted to let u know of the issue. Probably because it sat for awhile.
325 plus shipping
On u
The amp sounds great and has tons of power. It's a little on the big side. It's hard to explain but the amp dosent have a problem making anything sound good. It beats out any other amp I have just is too big.
462
511
10
896
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
rwlaney
rwlaney
tega cay
rwlaney
