Moving/broken stuff inside my capacitor..
As cheap as these things are, I'd just buy a new one if you think it is helping your system. My opinion is don't waste your time opening it up, if it is anything like that one linked in the above video, there is no fixing it even if you do open it.
As long as it is fully discharged, I don't think it would hurt cutting it open, but it must be fully discharged. I of course don't recommend it if you don't have experience doing such things. Rubber gloves, and care using tools is of course necessary, but why bother as cheap as these are.
The cap in that video sure does look like they skimped out, it doesn't have concrete, but might as well. 😂
Based on everything else you've said so far, I'm wondering exactly how you have the LoC connected "through your subwoofers". Is it possible that...
23
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
960
use the icon where it says insert image, icon. press that. How to get your pictures on your computer? Use your iPhone. Then transfer it to...
idan167
CarAudio.com Recruit
idan167
hispls
Brendon Jenness
    May 8, 2024
    May 8, 2024
