SOLD MTX 275x
  • 3
plugitin
She Bangs
6,906
Da U.P. eh?
MTX 275x
Amp works but has something like a feedback whine coming through the speakers. Was a strong amp for my comps. Have no idea whats wrong with it. Missing most of the speaker and power screws and only two mounting feet with her. Is used and is a little beat up.
Specs
$30.00 shipped.
Probably has a broken rca shield ground. Could be an easy fix.Do you have a multimeter?You could run a quick check on it. Good price on it. If I had the extra money I would snag it. Love these old school mtx amps. Good clean power.
i do, lemme know how to test her and ill take a peek. Thanks man
Do you have continuity between the rca shields and the NON bridging speaker terminals? Do you have roughly 1000 ohms between the rca shields and the gnd terminal of the amp?
If you can, try moving the rcas around while checking for continuity between the rca shields and the non bridging speaker terminals. If while moving them you get intermittent continuity you almost certainly have a bad shield ground.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
831
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
plugitin
She Bangs
plugitin
Da U.P. eh?
plugitin
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
