MTX TC3002 Bridged into 2 ohms?
  • 2
orion25
I have a MTX Thunder TC 3002. I just acquired a JL Audio 12W3-V3-2. The sub is 2 ohm (I was thinking it was a DVC 2 ohm when I bought it)..... Will I be able to run the JL with the TC3002 bridged for extended drives? I am not a "boomer" by any means. I have ran this setup for the past 2 days during my 20 minute drive to work while playing some "almost Boomer" music and have not had any problems. The amp does not even feel hot.
Should I be looking for a mono amp or can I continue to push the TC3002? I am not looking for the amp to last a lifetime but it needs to last long at least thru Christmas when we have to make a 6 hour one way trip. I have been out of car audio a long time (my last amp was an Orion 225 HCCA!!!). I am not sure if current amps can handle 1 ohm loads when they are not rated for them. The TC3002 manual does not exactly say no 1 ohm loads but it does not say they are OK either. Anybody got any experience or advice?
Thanks!
Thanks!
I have never heard of single 2 ohm coils(not a big sub guy)but if it is a single coil your amp is only stable at 4 ohms bridged
Yes the JL 12W3 is a 2 ohm single coil. I have since posted the MTX on Ebay and replaced it with an Alpine mono amp.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
833
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
orion25
orion25
In My House
orion25
    Jun 1, 2024
    May 31, 2024
