my amp keeps cutting out...why?
audioman
michigan
i have a jensen XA2100 200 W amp. it is pushing 2 12 JBL's 4 ohm. i have it bridged, and am rumming the speakers in parralell. it hits good and sounds fine but the protect function keeps coming on when i try pushing them. can anyone tell me why? i know jensen is not top of the line... but it is what i have for the time being. my old mtx amp kept blowing the fuse when i had it hooked up the same way also. please help!!!
audioman-try series/wiring the 2 jbl subs
call the two subs (sub 1 and sub 2)
take the negitive from sub 1 and wire it to
the positive of sub 2 then take the
positive of sub 1, and the negitive of sub 2
and wire it to your bridge amp (positive from
amp to sub 1 and negitive from amp to sub 2)
give it a try and see if the protection mode
comes on
Your amp is shutting down because it is overloaded. It can't handle the 2ohm mono load.
You can do what billet suggested which will give you an 8ohm mono load. Or you could just run each sub on a seperate channel.
it comes tomorrow and i cant wait. Thanks for spotting that amp and recommending it!
19
4K
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
287
448
  • Locked
736
audioman
audioman
michigan
ramos
