my system
Back when I actually had my 99 Grand Prix GT. I had it pretty built by the time I sold it. Right behind the drivers headlight the sheet metal was bent as sort of a ram air and the intake sits right behind that headlight. I did a 4" Spectre coupler at the throttle body to a 1.5' solid aluminum tube to a 9" Spectre intake filter right in that ram air dam.
Niiiice, i got a Z28 Im working on a 95 everything seems okay gonna be doing a few mods one a little something like that. But most def I bet that made a huge difference. It was okay in the rain or you put a screen to help with that??
improvements the red top under the hood 1g going into the car im getting a deka for the trunk and ill be using 1/0 for the qca we will see how it performs
That picture above is the only one Im like ehhhh about. Never been a fan of boxes sitting on a back seat. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Right after the air dam it dropped off and there was a solid shelf there that the old intake box used to sit in. It was elevated above that so the water would just run in and down. The filter never got wet or submerged.
Definately made a huge difference. It was one of the last things I did before I sold the car. Prior to that I did the tranny and a full ignition with some exhaust work.
it wont fit anywhere else and its only temporary until i get my 4 12s those will fit in the trunk i got a ported box made to fit in my trunk for those i just got these 15s in a trade so im using them and im not get my new amp or battery til next week
Niiiiice, well hopefully I work out my oil pressure ordeal and its not an internal issue and Ill be flying soon enough //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thats good man Im glad CA was able to help you, and trust bro theres always room for improvement. I know when u get some good bucks in your gonna wanna sound deaden the hell out of it and I promise you...Its like night and day.
Its probably something super obvious like a loose or dirty sensor or something. If its throwing a SES light Autozone, Advanced Autoparts, etc usually run a free diagnostics on those issues and can print off a list of possible causes for that code.
Well what is great is its a OBD1 which they dont do, but not is that it...its an OBD1 with an OBD2 connector no worries though. Gonna get the ALDL cable and read it through my laptop //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Wow super convenient. My new car has some crazy trick to it. If the MIL light goes off I just flip from off-acc power-off-acc power-off and hit the gas or something like that and it will display the code right where the mileage is on the odometer. Good luck getting that shiz fixed.
/endthread hijack
OP man you got to trust. Believe it or not there are alot of people here who know what they are talking about. And for gods sack do some fvcking research on the items your looking at. There is plenty of info between here, CACO, and DIYMA that you should be able to cover pretty much anything relatively quickly.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
220
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
629
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
markak134
Banned
markak134
pa
mendon mafia
