My very 1st Subwoofer enclosure build
Thanks. I was was going for that old Peavey Amp look, I believe that was the company. It's made of 3/4 MDF. I sealed it with a laquer based sanding sealer, put on 3 coats of filler primer and 3 coats of the purple base. All rustoleum 2x paint + primer. Then used the brush on to splatter. It took me 3 days to get up the nerve to do the splatter. Hahahaha
You did a nice job for your first box ever,well done that must knock hard.
10
906
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
GoT_2B_BuMpN
CarAudio.com Recruit
GoT_2B_BuMpN
No Conway, New Hampshire
Louisiana_CRX
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
