NE1 have a NEON?? Sub placement in folddown seats
  • 2
nissanrider06
VooDoo
1,377
Eagan, MN
A friend of mine has a plymoth neon, anyone know how big of a box we can do, im guessin were gonna have to do a in trunk build cuz its small!!! anyways both of his seats fold down and its a 4-door, how should we do the sub and ports??? i was thinking sub and port forward? if it matter its for t 12 in r's with 2000 watts //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
I've got a neon 2nd gen. 1st gens are different. Width max is about 32" for 1st, 34" for 2nd. If you want loud, then either take out the back seats and build a wall or build the box in the trunk with the subs firing up. Your best bet will be a wall since the trunk is so freakin small. You need to have breathing room otherwise you choke the subs potential output.
Yup. The problem with the firing up though, there will be cancelation issues depending on the placement. That's why a wall would be better. There are a few people who have done 4 cubes in a first gen with 18s, but the size of the box choked the output of the air movement in the trunk.
151
310
475
587
nissanrider06
VooDoo
nissanrider06
Eagan, MN
Spr0ket
    May 20, 2024
    May 20, 2024
