Lowflyin 10+ year member
Sit on my face, B*tch
On my boat we had a directed 650 5 channel powering 4 speakers and a kenwood sub. Well, there is something wrong with it because it cuts in and out so I am looking for a new amp with around the same power ratings. Thanks.
SPECIFICATIONS:
50 watts RMS per channel @ 4 ohm, 20 to 20,000 Hz,
75 watts RMS per channel @ 2 ohm, 20 to 20,000 Hz,
250 watts RMS (subwoofer channel) into 4 ohm,
350 watts RMS (subwoofer channel) into 2 ohm,
650 watts RMS (total system power ) into 2 ohm,
Dynamic Power Rating (minimum load/14.4VDC)
800 watts
Signal-to-Noise Ratio
Greater than 95 dB
Frequency response
20-20000 Hz ± 0.5 dB
Damping Factor @ 4 ohm
> 100
Input Impedance
20 kohm
Input Sensitivity
variable from 150mV to 8 volts
Output Impedance
stable to 2 ohm
Supply Voltage
9 to 16 VDC
Heat Sink Dimensions (H x W x L)
2" x 8-3/4" x 14-15/16"
SPECIFICATIONS:
800 watts
Greater than 95 dB
Frequency response
> 100
Input Impedance
20 kohm
Input Sensitivity
Output Impedance
stable to 2 ohm
Supply Voltage
9 to 16 VDC
