Need : A Pillar Build For Tweeter and Midrange [EDISON,NJ]
  • 2
hi, have you seen my build log? it may give you other ideas, the kicks have plenty of room.
i make tweeter spheres for vehicles, and i've used a few mid locations up in the dash/apillar.
what size speakers are you looking at (outside dimensions).
i use morel mt-22
and midrange is dls up 2.5i
here is the spec of midrange
Voice coil 52 mm / 2" Aluminium flat wire, 6 mm
Sensitivity 91 dB (1W/1m)
Magnet size 65 mm (2,56")
Mounting hole 82 mm (3,23")
Mounting depth 15 mm ( 0,59")
Outer diameter 100 mm (3,94")
i dont want to use at kicks..
i want to use in the pillars and dont want use spheres
just want to make hole and put that in.. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
can you build for me?
i love this (sorry i take your picture)
and for midrange,i want put below the tweeters
Gotcha. Nothing wrong with picking a goal.
A 4" mid is challenging to fit in our dash. I have done a few mockups.
I am going to work 2" mids back into my a pillars. They fit better.
I am too far from you to build your pillars. I wanted to share some of my experiences with our cars.
how about you build with your pillars and sell to me?
make it with hole,so i can put with screw
i want liket that picture.
this is what i wanted to do for 4" mid placement
this was pretty easy to make
i've tested both apillar mid and dash mid
apillar mid with dash tweeter worked out decent - apillar tweeter off-axis results in a loss of high frequency detail unless you have the right tweeters so you want to aim them back
this is that i want..mid in the a pillar
because my mid only 2.5 inch
then i want put the tweeter above the midrange..
dash no speaker..
can you do this for me?
235
247
595
511
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
crosed
crosed
Edison, NJ
crosed
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
