Need better suspension for all the weight in my trunk
  • 1
gsuchyta
rear end of my civic is saggin big time. I bought this car and it was already lowered and I believe it has adjustable gas shoks because it has that knob dial thing on the shoks but that doesn't really do anything when I turn it.
anyways my car rides like a brick especially my rear suspension the whole car jolts big time every time I hit a little bump much less a pot hole.
Is there any way to adjust my ride height with these gas shoks? Do I need to put more gas in them? What is that knob on the shoks supposed to do?
Also would going back to stock suspension help raise my back suspension?
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
6
79
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
180
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
134
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
478
gsuchyta
gsuchyta
Austin, Texas
gsuchyta
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
