Need help getting my back hatch window quite
  • 3
taylor3333
Ive got everything else on my car to stop rattling with dynamat. Now the only this making noise is the window. And I dont want to replace it with wood or anything. Is there any solution to making this window quite? Somehow sealing it better?
Its a 99 ford explorer, btw.
Thanks.
Try adding some weatherstripping around it to isolate it from the frame if you can.
Is there a wiper on it that is adding to the rattle?
That will probably help considerably. Beyond that, there's not going to be much you can do to quiet it down much without getting too "inventive" ie, fugly.
that kind of describes the sound when the common is lost between a pair of channels. you get some lows and it plays the difference between right...
8
993
11
658
723
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
958
taylor3333
taylor3333
charleston, sc
dkdub
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
