Need help with custom vented box for 12" sub
  • 5
I'm going to order the sundown guys!Now a matching amp, if I sell this one I might be able to get some more power out of it.
My current one is easily worth a 100 euro, so I'm looking at max 150 for an amp.
I need a 2 channel amp since I'll be bridging my dual 2ohm coiled Sundown with at least 500 rms
Any suggestions?
This^
[quote name='papermaker']https://www.caraudioshop.nl/30-cm-losse-subwoofer/ESX-Quantum-QE1222-30cm-Subwoofer
pretty ******* woofer. looks very solid. I'm sure they can give it to you for 200 euros.
13.5mm xmax 3" coil high BL cil will handle 1kw all day but its very efficient so 500 will get it ROCKIN.
use the current box designs with a 4" port unless you can get a 25" 6" port or you want to build a slot port on the rear wall facing sideways. it will like 2 cubes tuned to 34[/QUOTE]
I'm going with the Sundown I think: (1) Sundown Audio Subwoofer E Series 12 E12 Ev2 E12D2 V2 E12V2 Dual 2 Ohm | eBay
Xmax of 12mm, looks great imo: EV2 SERIES
You agree?
[quote name='Massive spl']http://youtu.be/1IhmNHrtmmk
Here's box plans if u wanted to build yourself
And powerbass Asa 1200.2 amp
PowerBass ASA 1200.2x (ASA1200.2x) 2400W 2-Channel Car Amplifier
AUDIOXSXU6
This is a 18% off code if you order an amp from sonic eletronix website[/QUOTE]
@Massive spl I can't buy off their website sadly, it's only USA.
What about this Soundstorm MOSFET 2CH 1000W Power Amplifier Remote Woofer Level Control | eBay
Any suggestions?
* NEW * CAB-1600.1 Amplifier - Car Audio Bargain
wire it from d2 in parallel to 1 ohm
you dont need to bridge if you get a mono amp
[quote name='Aygodriver1212']I'm going to order the sundown guys!
Any suggestions?[/QUOTE]
[quote name='wew lad']* NEW * CAB-1600.1 Amplifier - Car Audio Bargain
you dont need to bridge if you get a mono amp[/QUOTE]
Out of stock
---------- Post added at 05:00 PM ---------- Previous post was at 05:00 PM ----------
[quote name='Aygodriver1212']I'm going with the Sundown I think: (1) Sundown Audio Subwoofer E Series 12 E12 Ev2 E12D2 V2 E12V2 Dual 2 Ohm | eBay
You agree?
What about this Soundstorm MOSFET 2CH 1000W Power Amplifier Remote Woofer Level Control | eBay[/QUOTE]
No that sound storm is crap
can you get a hifonics brx 2400.1 or whatever it is? I think the x is the better model or is it the z? **** idk
if you can get massive audio their amps arent bad
I can't get Hifonics, there are only few available here and they're quite expensive.
Which ones should I get from Massive Audio? Not sure if I can get them but I can check. Edit: Massive isn't the way to go here.
431
824
841
Aygodriver1212
Aygodriver1212
Amsterdam
Aygodriver1212
    May 31, 2024
    May 24, 2024
