Need help with distribution block
I have a skar skv2 2500 and a pioneer GM-D8604 and i know i need a distribution block just wondering if i can use a 0 gauge in and have a 0 gauge and a 4 gauge coming out? All help is appreciated, thank you.
Absolutely with a distro block with those outlets.You can even get a reducer for the 4ga to fit the 0ga outlet for a much tighter fit. Some blocks come with reducing sleeves
40495
Just wondering if i can have 1 input and have 2 outputs or will i have to use two inputs for the distribution block on the bottom?
You could make the bottom one work with one power input by adding a bar across on that end and would have two outputs.
Otherwise in stock form the bottom one is a dual input/output.
700
974
940
Sye671
Sye671
Guam
some dude
Decebal
    Jun 10, 2024
