need to build a enclosure for 2 12in hcca orions help please..
  • Thread starter Starkillers2019
  • Start date
  • Replies 33
  • Views 6K
Cool story bro....
Just catching up on this thread.... you came on here and literally asked if you should go sealed or ported, then proceeded to get butthurt when the overwhelming response was to go ported. Why are you even on here? Clearly, your intent is not to heed the great advice being given to you. Why would you get those subs, upgrade your alt, and add batteries if you are going to cage those beasts in a sealed enclosure? In the end, it's your money and your system, so you're free to do whatever you want (even if it's absolutely f*****g retarded).
ended up build , with one like in picture   except no terminals  yet..   need to get some lug terminals .
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
867
JL has some slim subs, maybe one of those will fit. Alpine has some pretty small amps, you could put that/those under the passenger seat? i like...
932
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
146
Guest
fithwheel
    May 16, 2024
    May 16, 2024
