New amp,sub,speakers (need your opinion for setup)
  • 1
Drifter mike
CarAudio.com Recruit
32
Greece
Hello,
Last year i installed in my mom's car (Mercedes A140 W168) an aftermarket head unit (Pioneer DEH-S320BT 50*4watt) and also changed the stock speakers with new: JBL Stage 2 604C front (6.5'', 45 watt RMS, 91db sensitivity, 4 ohm) and MTX TX-250C rear (5.25'', 55 watt RMS, 91.5 db sensitivity, 4 ohm).
Now i want to improve the sound a little bit so i have on mind buying a TRF M600.4AB amplifier (4 channels, 600 watt RMS max, max RMS power 4ohm 80W*4, max RMS power 2ohm 150W*4, max RMS power bridged 4ohm 300W*2), a TRF VLSW123D2 Subwoofer (12'', 350 watt RMS, dual 2ohm voice coil) and 2 Hertz Uno X 690 speakers (3 way, 6*9", 85 watt RMS, 94 db SPL sensitivity, 4 ohm).
The subwoofer will be placed in a ported, 35-40L, custom box and the two hertz speakers on car's shelf. Both hertz speakers will be connected to the amplifier (channel 1 and 2) and the subwoofer will be connected to bridged channels 3 and 4 after connecting the ''two voice coils'' of the subwoofer in series so the final resistance will be 4 ohms (so the power that the subwoofer will get from the amp will be 300 watt RMS). JBL and MTX speakers will not be amplified.
Could you please tell me your opinion about this setup? Do you think it worths ?
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
You can use two front channels to power the full range speakers, then use the rear channels to power a sub. IMO, for that price I would rather use...
551
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
674
Drifter mike
Drifter mike
Greece
Drifter mike
audiobaun
    May 19, 2024
    May 19, 2024
