New Head Unit Causes Fuse To Blow
cstanfield13
4
NC
I recently purchased the Pioneer AVH-4400BH from Crutchfield and installed it in my 2008 Honda Accord LX-P. From what I know, I have installed it correctly using a wiring harness and a parking brake bypass. However, each time I turn the car on, the 7.5A fuse that controls the dash illumination blows. It has blown 3 fuses almost instantly so I know something must be wrong. The headunit works flawlessly so I am not sure what is wrong. Any suggestions would be of great help!
Is it possible you may have damaged some wiring further in the dash, did you tug on anything to access the plugs for your harness? Thats all I can think of since you didn't splice into anything and the HU is working, that or just a poorly timed coincidence?
It sounds like the illumination wire (orange/white) from the head unit isn't connected to the correct wire in the harness, or the orange wire in the harness is shorting to something in the dash. Since normally installing a harnesses is just matching colors, I would start with checking the orange wire for any exposed copper which could be shorting. The wire should be loose so just tape it up and try to power up it up. If the fuse blows again disconnect the orange/white wire from the harness and power it up. If the fuse doesn't blow with the wire disconnected you can leave it disconnected or try connecting the orange/white from the radio to the orange in the harness and try again.
ive seen a lot of honda's have that problem. I usually put a 10a in its place.
Your doing it wrong then.
Chances are its a short somewhere. Did you solder and heatshrink the harnesses like you should have? If not I would spend the time to do it right.
2.5a is unlikely to cause any problems. and the chances of 7.5a being enough to supply the deck with sufficient juice is also unlikely and everything else on the circuit.
Aftermarket head units do not use the illumination circuit to power anything, all the "juice" for the head units lights is supplied through the 12V constant circuit. The head unit uses the illumination circuit to trigger a dimmer for the display, in other words it's a very low current draw that won't blow fuses if it is wired correctly.
Thanks for all the input guys. So I pulled my head unit back out again and I realized that I have the orange/white dimmer wire connected the orange/white wire of the head unit. There is also a solid orange wire that is for illumination/dash light. Should this be connected instead? My head unit supports auto dimming so how would I hook these 3 wires up to also make sure it still auto-dims? There are no other wires to connect the dimmer to. Will I even be able to use this auto-dim feature if I connect the orange/white wire from the head unit to the orange wire of the wire harness?
Buy some spare fuses, it really sounds more like the solid orange wire is shorting and blowing the fuse. Be sure it is taped up and there is no exposed copper that could be contacting metal behind the dash, before you try anything else.
most Hondas have this problem. My 95 civic coupe had it. It happens when you go from stock to aftermarket radios. I just simply upped my fuse from a 7.5 to a 10 amp this was the instruction I was given from 10+ honda tech . com members. Never had a problem since. ,you can always just run your own constant power from the battery and that should solve the problem as well
the illumination of the dash pulls its juice from a constat source, just so happens to be the same circuit the deck constant pulls from. It overloads the circuit and pop. Real common problem.
Technically there is only one 12V constant source the battery. The question is does the head unit in the Honda get it's 12V constant through the illumination circuit. If that is really what is happening with Hondas, then the answer is not to over fuse, that fuse should be bypassed. In other words run the 12V constant straight from the battery, it's been a while since I bought a Pioneer but they used to supply nice long wires with fuse holders just for these situations. You don't even need to use all the wire and fuse holder, you can probably find an empty spot in the fuse panel to run a new 12V constant just for the head unit. So why would anyone suggest over fusing?
Lol i dont use thoughs wires AT ALL, the illumination or dimmer orange/orange white. All i connect is main power(red), signal(yellow) and ground. But i use external amps for all my speakers. Ive never used any of the other wires and had them do anything at all. Unless maybe i had a power retractable antenna.
6
364
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
678
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
748
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
918
cstanfield13
cstanfield13
NC
CrossoverOre
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
