New headunit = static in speakers
  • 2
gb22
IN
I recently installed a new headunit in my car(JVC). Now my speakers are crackling like crazy. Even with the volume all the way down, they have static coming out of them. Could this be a wiring problem? Or road noise? Because i can hear the static change when i press on the gas pedal a little, kinda like a whistle.
Any tips on how to get rid of this? Maybe take the unit out and rewire everything? I didnt have this problem with the stock unit.
what ^ said. amp gain setting info, test tones are at the very bottom...
437
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
gb22
gb22
IN
usarmy1494
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
