New Processor
....Do what you want.
Im sorry if I wasn't too clear earlier, the MS-8 is already gone, sold it to a friend for $100 who said he could fix it, he ended up destroying it more. I was asking about other processors, not how to deal with the broken one
You should have called JBL before writing that MS8 off like that.
Try a Helix or Arc audio Processor. All you have to do is look at the reviews and search for other processors.
I see, that information would have been helpful. What do you want your new processor to do for you? Do you need good center channel support? Rear fill?
No center channel or rear fill, I go for sql as much as possible, so a processor with time alignment, center stage, preferably digital, at least 8 channels
360.3 is great. However if you keep your computer up to date it won't be good for you. It locks up with some versions of net framework. For me that's not a problem because the computer I use is barebones. Also you have to set your screen resolution to whatever the software (I don't remember what that is) because the software window does not adjust size.
I must have had a brain fart, but I realized a preamp is needed in the way I mentioned. So why is it that preamp is non trivial here? Anyway...
13
I am building a nice system in my Ford Excursion using high end 3 way component speakers in the front doors in custom speaker pods, and using 2...
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
logan963
logan963
Dallas, TX
TDot
winkychevelle
    Jun 3, 2024
