New System is in!
Well just installed my 2 T4-12's on my PCA-2000D, it thumps real hard. I can take pics and vids if you guys like later. No Voltage drops either
naw dont worry about pictures and vids....we rather read how loud it is and how it looks:rolleyes:
My camera ***** too bad to catch much on the video camera.. anyways havent really got a chance to vacuum the loose wire and clean it all up
by the looks of it I'd say it does rattles the s***t out your trunk, and it looks like you just had enough space to put in. I have a question I know most people do this but is it a good idea to screw the amp into the box, I mean doesn't it make it easier for someone to steal all you stuff in one swoop. So how do you like it?
looks good bro my thing with amps on back of boxes is the amps heat up with the solder on the circuit boards and the box is vibrating. i always tought the components on the board would work themselves out eventualy or not
Amps temps seem to be fine from what i can see. Well you also have to remember the box weighs over 180 Lbs at least. Its really hard to even tip it up with everything on it. Im gonna get some metal brackets as well and screw it all into the trunk. But it moves the entire mirror down, i have to adjust frequently. The song "Ya'll cant deny it" absolutely ****s my **** up lol. Its so sick
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
178
600
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
Lucid15
Always open to trades!
Lucid15
Portland,OR
Lucid15
    May 31, 2024
    May 24, 2024
