Non-Working DC 12k
  • 4
schrummy
Ames, Iowa
1. Product:
DC 12k
2. Specs:
Key Features
• .5 ohm stable
• Variable low pass filter
• Variable subsonic filter
• Variable bass boost
• Wired remote control
• 2 channel
• Triple 0 awg power and ground inputs
We recommend for installation
• 1 upgraded battery under the hood
• 3 extra 800ci battery in the rear
• Minimum of two 0 awg ran from the front battery to the rear batterys
• All 0 awg power and ground inputs on amp must have 0 awg ran to them for a total of 6 runs into the amp
• 2 upgraded aftermarket alternators
• Dash mounted voltage meter
Features Voltage 12.0K
Output Power (RMS) 4 ohm 14.4V 1,200W x 2
2 ohm 2,100W x 2
1 ohm 3,400W x 2
.5 ohm 12V 4,200W x 2
.5 ohm 14.4V 5,500W x 2
.5 ohm 16V 6,500W x 2
Working Voltage 8.5V~16V
Frequency Response Hz (-3dB) Hz 20~250
Signal to Noise Ratio dB 100
Damping factor 250
Efficiency @ 4ohm % 85%
Low Level Input V 6V - 0.2mV
Line Output Yes
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Bass Boost
( @45Hz ) Switchable
Variable dB 0 ~ 9
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Remote Level Control Yes
Double Sided board 2 oz
3 oz Yes
Indicator Power Yes
Protection Yes
Speaker & Power terminal Mold Type Yes
Power Gauge 0Ga x 3
Fuses External Yes
Heatsink Length mm (inch) 850(33.46)
3. Description/Condition:
Cosmetic:
i would rate the amp 8/10. Minor face scratches, but scratches on the mounting feet, and underbelly of the amp.
Mechanically:
the amp does turn on, however somewhere on the signal processing side of the amp, there is a broken solder connection (see pics). There are no burnt components on this amp. I just do not have the knowledge to fix this amp my self, nor do i have the time to send that amp to DBr.
4. Price: :
I see these go used in working order for around 1700 shipped.... since mine doesnt work, i will price mine under the assumption that it would need a new board (i guess $600 for all repairs and shipping, shouldn't even be close to that)
that puts me at $1100 for the amp, however, i will also take $150 off due to the new owner having to either repair the amp, or sending it in to get fixed.
So i will sale the amp at $950 shipped... OBO
any questions or concerns, please do not hesitate to send me a text (712) 660-0703. I will answer back as soon as i can.
5. Pictures:
Didnt let me post all pics
Problem areas on the board
the capacitor there is loose and may not be making contact with the board.
This piece has completely separated its self from the board. I was able to re-align everything and applied pressure to the top of it to place it back on the board. we then tried turning it back on and still no signal made it out of the amp. everything else on the board looks correct.
once again, any question, please do not hesitate to ask. if you would not like to text me, you may either PM me here, or use my email, mschramm@iastate.edu. this email is synced with my phone so a reply should be quick.
yes sir.... was getting around 5500 at 2 ohms bridged... not really looking for trades, but what do you have???
powerbass 3k repaired by tim webb on caco. 2 ed 3.8s and a onyx 4.60 with 300 bones cash in one of the packages.
run your subwoofer amp on RCAs from your head unit. Tap the loc in the rear speakers or the wiring harness in the back of your head unit to the...
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
schrummy
schrummy
Ames, Iowa
schrummy
    Jun 1, 2024
    May 31, 2024
