Official CarAudio.com Big 3 Thread
nope...
ok...here it is...
Battery pos. to Alternator
Battery Neg. to Chassis
Chassis to engine
Use a 4 ga. cable wire or bigger.
It does not matter what color it is. Just go with the colors you want.
And THAT IS IT...
simple uh...
Good luck
What should you do if the car has the battery hidden in the wheel well(Sebring, Corvette) and there are teminals in the engine compartment that everything is hooked to? Would it just be two more wires run to the battery?
jee
what is the engine block and what does it look like?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
ever opened that hinged thing in the front? if so, see that big thing that takes up most of the space in there? well thats the engine. the block would be whats under all of the accy's and wires/hoses. anything metal that is attached to the block will also serve the same purpose (electrically) as the block.
Looks like I called this one correctly and OP hasn't been back to post any glowing reviews either.
21
5K
  • Locked
Watch out For USER ID: theasw232 and email mikescott6678@gmail.com !!!!! You've been Warned!
johnecon2001
SSA/ROE Super-Møderator
johnecon2001
Phoenix, AZ
2023 LTZ
SlugButter
    May 4, 2024
slater
    May 2, 2024
