oplease read this i need help!!
  • Thread starter <rob>
  • Start date
  • Replies 4
  • Views 1K
  • 1
<rob>
Guest
Ive just brought a rockford bd500.1 amp and i am goin to buy 2 JL udio W3s to run off it. the thing i am stuck with is what should i get the 2ohm 4ohm or 6ohm vioce coils. please help need to know before i spend all that money cheers.
if they are dvc get the 4 ohms so you you can run it at a 1ohm load this will give you the most power to the subs. if they are svc go with the 2ohm.
yeah they are dvc but i was thinking of running them at 2ohm will that work with the 4ohm speakers ok does it not mean they can only be run at 4 ohms
I you wanna run your amp at a 2 ohm load then single 4 ohm voice coils will get you there with minimal wiring ( this is going to be the easiest)
2ohms should be plenty of power for the W3s so why push the amp and just to get a littel more power and a bit more distortion..just my opinion.
Mike
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
480
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
369
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
406
Guest
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
