oscillating buzzing over bluetooth Pioneer 80PRS
  • 1
Bun-Bun
Saskatoon
People talking to me on the phone complain of a buzzing sound. I have borrowed my gf's phone and confirmed this myself. It's fine on my end but for the person on the other end there is a oscillating buzzing sound.
I have tried connecting my gf's phone to the headunit and calling my phone. Noise is still there (Hers is an iPhone 4S mine is an HTC One)
I have tried disconnecting the mic to see if it was picking up something. Noise is still there.
I have tried disconnecting the radio antennae and cutting the illumination wire. noise is still there.
I have tried disconnecting my amps and turning them off. Noise is still there.
The HU is wired directly to the battery in my trunk (separate from the car battery under the hood).
Noise is present whether the engine is running or not or whether the key is on ignition or accessory.
Next I am going to try taking the HU out of my car and running it on my bench with a power supply.
Any other ideas? I am really starting to think I have a dud HU.
Still does it. Has to be the head unit.
Local dealer doesn't want to replace it.
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
743
Bun-Bun
Bun-Bun
Saskatoon
Bun-Bun
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
