Pac LD-10 Line Driver Wiring
  • 6
Ripkon
CarAudio.com Regular
185
37
Virginia
I Received my Line Driver yesterday and connected it using 3' Sky High RCA and KnuKonceptz 20' Cable. I wired the Ground to the Stereo Harness and the Red 12v to the Remote Turn on HU. I had the Gains set all the way to zero, but once i turned them up then tried to back them down it would make a solid buzzing sound. I had to turn the car off and back on for it to stop. Any have experience with this and the best wiring method?
So it doesnt have constant power draw.
From manufacturer: Connect red wire to a 12V+ DC constant source, a switched ACC power, or
 a relay switched by a remote Amplifier turn-on lead.
I use a PAC LD10, but my configuration is very unique because I use it to boost the signal from my phone directly into the amp.
I wired the positive to a switch so I can turn it on and off, the same switch also controls the remote turn on lead to my amp.
Never had any buzzing issues like you described. Maybe try grounding to the chassis instead of the radio harness.
It is important to not wire the LOC power input directly to the head unit remote.  It says to use a relay to isolate the unit from the remote output because the remote output can only source a few milliamps.  Always a good idea to have the power for the LOC turn on/off with the head unit.  Add a relay as recommended.  That won't help the buzzing but it will prevent damage to the head unit.
Buzzing is usually a signal grounding issue.  As mentioned, a long ground wire is not recommended.  Ground at the amp chassis ground.   Ensure that's a proper ground connection (tight, bolted, bare metal, etc).
SWITCHED doesnt stay on all the time. Notice it says a RELAY when using the remote wire?
It just boosts the signal that is fed into it, if the input signal ***** to begin with then the output will **** too.
I only play test tones through mine for strictly SPL purposes so I can't comment on its actual sound quality.
My hu only has 2v output. It's a cheap pioneer double din. The outputs sound great. I was just trying to boost the volts.  With the pac hooked up it sounds like its traveling down a long hallway (if that makes sense)  I may try and get the Dayton dsp
You might as well bypass the headunit and run your audio through bluetooth straight to the Dayton DSP. @Jeffdachef swears by this method.
Nope, Either or. If you own both, then it's a loss on one or the other less what you sell it for, right? The PAC is an easier install and that...
7
Yeah, so many OEM bass remotes are useless the way the control the bass boost circuit. Boosting 40hz or whatever frequency, is again nearly...
Ripkon
Ripkon
Virginia
Ripkon
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
