Parking lights won't turn off!!! 2003 Saturn Ion - Kenwood BT308U
  • 3
I installed a Kenwood BT308U with a Metra wire harness for my 2003 Saturn Ion. I soldered the wires (there was an orange, orange/white, black/white, and pink wire on the harness that did not *match up with the receiver wires) and it works great- Except my parking lights will not turn off when I turn the car off and take the keys out. When I unhook the wire harness, the parking lights go off.
What did I do wrong? Are these extra wires supposed to be hooked up to anything? How can I fix this? Please help!
Thank you in advance!!!
Orange wire normal connects to radio lights. That wire was probably touching a live wire and forcing the lighting relay to remain on.
Now that you have learned to Never leave exposed wires check your fuses and if they're all good then you may have burnt the relay.
Hi all my first post here ,.... I just purchased A Halo 9 F905D which I am installing into my Renault Master 2009 based motorhome,...... My first...
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
5
831
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
8
hawkeyes1989
hawkeyes1989
United States
bigfluke 773
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
