Pioneer hu issue iphone etc
  • 6
mdsniper7
tampa fl
So I have a pioneer 4000 nex that was installed and everything works great. However there is one issue every time I play through the USB iPod cable I get distortion some times or like a pop sound etc. I have tried other iPhone 5s and same issue anyone heard of this before any advice would be great ty
Make sure the USB is plugged in tight in the back, mine was a little loose and did the same thing. Swap out your cable from the USB to the phone with a different one, they can go bad. You can stream via Bluetooth too, but it's not as solid a connection.
From my research Bluetooth quality is not very good and I have a pioneer with iphone 5 and have no issues. Is the cable a apple cable? also, try restarting your phone just might get lucky and reset things.
I've got a 16GB memory card full of music in my 4000NEX and I have been using Bluetooth more often. The quality is exactly the same over BT with my HTC One M8 playing through Poweramp. Trust your ears, not online research, because Bluetooth is very underrated today.
Try wiring it without bypassing the parking brake, load your custom background, and install the bypass later. Unless someone else has a quick fix.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
458
Google can... Query DEH-X1850UB faceplate replacement.
mdsniper7
mdsniper7
tampa fl
mdsniper7
    Jun 1, 2024
    May 31, 2024
