Please help! Head unit problem.
Chase29
Please help me. I am installing a new head unit into my 2001 dodge dakota, but am getting no power through the accesory power wire. The previous owner had both the battery and accesory wires from the head unit going to the battery wire in the truck. (See pic) Are there any problems that could be caused by doing it this way besides the head unit draing the battery if i dont turn it off? Any help would be appreciated. FullSizeRender.jpg
i dont think pic is showing up but the yellow battery wire has a fuse and is then connected to the red accessory wire which are then connected to just the yellow battery wire in The trucks harness. Hopefully you understand what im trying to explain.
No. You just need to tap into a keyed 12 volt source, whether it's an unused outlet on fuse box, or the cigarette lighter wire, or some other switched wire. Very easy to do since you have a dmm.
Ok thanks ill give it a try this week.
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
981
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
Chase29
Chase29
Los Angeles, CA
optimusX
    Jun 1, 2024
    May 31, 2024
