PLEASE READ need help setting up
  • 3
Rafaelv
I recently got a system in my car & i am fairly new on what the bass boost & gain & xover means so i wanted to see what would be the best settings to have it on. I have a kicker compS 12in with a Kicker CXA 600.1 amp i want the car to sound good & as loud as if can get without sounding bad so what would you guys recommend on putting the settings. Thanks for your time ??
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
634
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
530
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
Rafaelv
Rafaelv
Denver, CO
celicaboy84
winkychevelle
    Jun 3, 2024
