Protection mode???
  • 3
Kbelknapk
So today my almost brand new kenwood excelon x500-1 went into protection mode. After checking the ground, fuses and unplugging all wires except for the power and ground the problem still proceeded. I went and bought a brand new kicker dx1000.1 and the same thing is still happening?
Does any one have any other ideas?
My 4 Chanel amp is on the same spot but the other side of the car and its fine. My system has been working fine for a week now lol this is the first problem I've had with it.
So no paint on the ground tied directly into your frame ?
Just cause its on a 4 channel doesn't mean it's right....
I have 4 gauge running to the back of the car and a splitter sends 8 gauge to both of my amps (my 4 Chanel and my mono block). Both amps are grounded under my back seat to the frame in identical locations on opposite sides of car. The 4 Chanel amplifier is working fine but I've tried 3 different amps now where my mono block goes and they all immediately go into protection :/
Might be to much power to split off one run of 4 gauge try undoing the splitter run 4 gauge directly to sub amp see if it stays on then you'll know forsure
Ok thank you, I'll check where the remote wire is connected and get back to you.
952
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
8
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
6K
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
Thank you for the info and advice. I really appreciate the help. I will double check my wiring tonight or tomorrow.
20
4K
Kbelknapk
Kbelknapk
Rochester ny
Kbelknapk
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
