KickerInACruze
Hello everyone, I just purchased a new ported enclosure for the Kicker solo baric l7 12" that I just purchased. I was soldering the speaker wire to the terminal inside the enclosure and I checked 3 times before i began soldering to make sure I had the positive to positive and so on. After finishing up my work i realized that I soldered the positive to the negative terminal. Now before I take it apart i was thinking that i could just switch how I connect the speaker wires from the amp to match how I soldered the terminal and then I could switch the way I hook it to the subwoofer. Would that work or should I take it apart and re solder the terminal?
