Question on which amp or both
  • 2
i'd run them off the one amp to start with, if you find they arnt loud enough or you want to send them more power, then install the second amp
I'm already running off the alpine, which is seeing a 3 ohm load per channel, with db okur a71001.1 which was used for a jl stealthbox that I changed the sub in it to a dvc infinity and also a jl audio 10 tw3. I am replacing the stealth box with a custom made center console with a w7 inside, and switching the db okur a1100.1 to a Rockford T1000. The vehicle is an 08 Sierra extended cab. One set of components in front door other in rear. I know I can bi/amp the components, but will I loose spl and gain sql with the addition of the second component amp. Any advice on which way to go would be appreciated. Thanks
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
681
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
Minkos6
Minkos6
North Huntingdon, PA
Minkos6
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
